Discuss Help needed for mosaics in the Canada Tile Advice area at TilersForums.com.
Steve Cousens
Checked source web site does say can be use in wet areas not sure weather need different adhesive ? Thanks for other advice on back board
Dumbo
failure waiting to happen . So if you change the adhesive to an epoxy adhesive how are you going to stop water getting to your other adhesive .
Steve Cousens
Had thought of in shower area only doing normal tiles leaving gap for mosaics the fitting thin cement board making sure no gaps then mosaic on top ? Mmm might be talking her out out shower area maybe better shout around bath be ok as it’s 300mm upto border .
Reply to Help needed for mosaics in the Canada Tile Advice area at TilersForums.com
