Gap filling on walls
F
Fusion Tiling
Evening all
Just removed tiles in a kitchen and the substrate is plaster which has some big chunks missing approx 1 inch deep. I would normally skim the walls flat,but I want to know what I could use so I can tile onto without a long delay. The tiles going on are small ceramics approx 20 x 10. Wafer thin so no weight issues. I was going to use bal white star as an adhesive but no sure now, all depends on results from this request.
you could use rapid set cement, i used a lafarge one recently and it was rock solid after 10 minutes . i tiled it a couple of hours later
Thanks mike
Could I use rapid set tile adhesive as a filler, then use adhesive over that once set?
You could but do it in a few layers but prime the plaster first with an acrylic primer, not pva..
One coat patching plaster. No need for expensive products. I use the one from wickes , rapid setting
Thanks Dave,but bal render only about a tenner a bag,will not break the bank.
Fusion Tiling,
DHTiling,
Fusion Tiling,
DHTiling,
