Discuss floor tiling questions in the Australia Tiling Forum area at TilersForums.com.
R
reeves1985
I will be tiling my bathroom floor as part of my bathroom refub
Just want to get some opinions on prep for tiling
The floor area is only small less than 5 sqm over old floorboards.
Just wondering what the best was to go about prepping the floor and what to use as a sub base
As it stands the boards are in good condition and solid which I will be adding screws to.
The tile I'm going to be using is a 7mm ceramic
Reply to floor tiling questions in the Australia Tiling Forum area at TilersForums.com
  • Question
Bathroom floor. I would be grateful for advice on how to prepare my bathroom sub floor ready for tiling.I have removed the floor boards and plan to lay 18mm WBP plywood.The question is, what...
  • Question
  • Question
  • Question
