Discuss Floor prep in the UK Tiling Forum area at TilersForums.com.
Points
301
Hull
Hi all I have a bathroom to do and a small floor area less than 2m2 the floor is joist with 18 mm ply on top, I cannot feel any deflection, my question is would you tile straight onto this small area with a flexible adhesive or overboard it ? Thanks in advance fir any advice
I
Ian
If it's deflection free I'd still overboard it with 6mm hardie, simply for a better surface to tile to. What tiles are you fitting?
Edit, fix the hardie with flex adhesive and screw every 200mm. Apologies if you already know this!
I
Ian
Stick and screw 6mm hardie then tile. Don't forget the expansion gaps between the boards and tape the joints (not that there will be many joints on a 2m floor!)
russ1980
i agree with the above.Just done a similar floor myself and i love the stuff.When i first started tiling i was told 6mm ply is more than enough but i know better now,thats what happens when you listen to so called tilers/bathroom fitters.The best advice i've recieved on all areas of tiling so far has come from this site.So thanks everyone,:thumbsup:
Reply to Floor prep in the UK Tiling Forum area at TilersForums.com
