Flexible Bucket Liners - Market Research!
Fair enough. I'll give them a go when they're ready, you never know, I could be your Norwegian salesman ;-)
Go on dragons den with it you might get some investment. ....at the very least free advertising. ..
Even the tight arse scot might part with some money. .lol
Careful there, I am a Scot 🙂
Problem is that I'm struggling to see a bigger market for them than just tilers if that makes sense! Usually there is a good reason why something hasn't been done already!
You can get a black bucket for £1.50 now which lasts a decent length of time! Having said that these Weber fast set flexible with 25% extra was going off very quick the last couple of days and I was cleaning out 2 often and the buckets may not last very long.
However as I may mix up 10 - 15 buckets a day I'd rather use 4 buckets and throw them away then say 15 liners for £7.50 (@ 50p each).
But good luck and I'd certainly try them.
How much more tiling could you do in a day if you didn't have to clean out 10-15 buckets per day though?
Where can you get a black flexi bucket for £1.50? I will buy them instead if you can let me have a link/vendor!
Black bucket for £1.50 from BQ ( I didn't say flexi) but this is a better quality bucket than the £1.00 one they also sell.
I use the bal buckets and get them for £3 a pop. I have had 7 for the last 6 months and they have went through everything from grout to adhesive to slc. The more and more I try to keep them ridiculously clean the more time I waste, although I do keep them very clean.
As said previously, I seem to be using standard set more and more mixing two buckets up at a time due to the size of the tiles. Floors are generally rapid set.
Good luck with the venture pal !
cr0ft,
cam_low,
cr0ft,
cam_low,
