Discuss FLEX Polisher Grinder with Dust Extraction. in the Australia Tiling Forum area at TilersForums.com.
C
Concrete guy
We've been asked a number of times for a machine that can be used for Polishing/light grinding that has a dust extraction shroud.
We now stock the Flex SE 14-2 125 SET 230v.
White Room
Like the shroud, better than my Bocsh one which I needed to make adjustments to get it to stay on.
C
Concrete guy
Would it work cutting tiles Allan?
No it wouldn't, it's a shroud designed for the machine being used as a polisher/surface grinder (in the orientation pictured or held against a vertical wall).
The shrouds for cutting really aren't very effective and so far all the ones I've looked at are a bit Heath Robinson.
Plus this machine has a speed range of 600 - 2100 rpm so it's not really designed for cutting.
It's the kind of thing you'd use to remove localised lumps and bumps on a wall or in a floor screed. Or polish the edges of floor after doing the main area with a large rotary machine.
C
Concrete guy
Not at the moment, however there is a 110v 125mm polisher/grinder with dust extraction in the pipeline.
They currently produce a machine at 115mm but it's too small, it needs to be a 5" machine and they are responding to requests for one.
Reply to FLEX Polisher Grinder with Dust Extraction. in the Australia Tiling Forum area at TilersForums.com
