tay1974
Hi All,
I have been asked to quote my first UFH job and would like some help.
Basically the customer is knocking down the wall between his kitchen and dining room to make one decent size kitchen/diner, this will be approx 20 sq metres once completed.
He has asked me to install UFH and then tile with porcelain tiles.
My questions:
1) As the floor at the moment is floor boards, do I need to lay plywood on top of the boards before laying the UFH?
If I do need to lay plywood what thickness does it need to be?
2) The customer is worried about the height of the floor after we have layed the plywood, UFH, adhesive and tiles as he does not want it being much higher than the hallway floor. Is there anything that can be done so the floor does not come up too high?
3) The room once build will be fairly square apart from the archway between the kitchen/diner. Would you selct UFH mats for cables?
4) Which UFH would you use? Devi, WarmUp, UHeat?
5) As I need to cover 20 sq metres and most suppliers do not offer this size kit can you connect two or more matts together?
Paul
My questions:
Paul
