Finding the highest point of a floor
F
FreeD
Say u've got a 30m2 floor and you want to start tiling from the highest point...how do u find the highest point?
thanks
Or a long level with a few spacers stuck to each end, the point that is closest to the bottom edge of the level when you lay it down is the highest. Depending on how high the high point is depends on how many spacers youll have to stick to it. I just cellotape them on as and when.
See wht ure saying Oli but on a large floor which is 10m wide how do u know that one side isn't higher than the other...as re level is only 1.5m long?
Granted its more of a technique for checking the flatness of a floor to decide if it is withing acceptable tolerance or if it needs SLC'ing.
Which level are you thinking of getting?
I don't know m8...think i will need a seperate one for walls and floors...i've seen some on tradetiler...why can u recommend 1?
whats accectable tolerance 2-3mm?
Another way to check levels around a room, is to run a datum line around the room, say 6 inches up from the floor using a long level. Then measure down from datum line to check high/low spots.
I have a 1.9mtr Stanley Fatmax Level, and use Oli's method to measure acroos the centre of the room.
Another option is to use a water level, these are great for measuring through multi rooms.
Tags Tags
floor usa
FreeD,
smurf21,
FreeD,
smurf21,
