Discuss Dot & Dab PVA in the UK Tiling Forum area at TilersForums.com.
johnryan
I did the drywall course in Penrith with Gyproc and the stressed you should only dampen the substrate with water when using drywall adhesive.
that's what i thought. just splash water up the walls to dampen it a bit.
Barry bp
thanks for all your input two different plasters i have used do add PVA as long as well diluted I think for the time being I will carry on It does help with dust and stop brick and block drying too quick:thumbsup:
Dan
Admin
1,318
Staffordshire, UK
I have never put any Pva on the wall before dry walling, damping the wall has allways been adequate.
If you put the finish on just as the browning is beginning to set there should no problem with any suction.
Let's point out what the problem is with it for most of us, it's the fact cement-based products mix with plaster which causes the two to de-bond (a tiny chemical reaction causes the two to sort of cause atom-sized explosions, causing the two particles to not bond). So providing we're not talking about cement on plaster, plaster on cement, I think there's no problem in using PVA.
Sirapite (a gypsum finish)was used on cement backings for a large number of years with no problems
i've erased my post. Doug said the same. i thought something wasn't right there with what I said. :thumbsup:
I'll just shut up then lol
DHTiling
IMO, PVA should not be used where an adhesive type product..gypsum or cement based relies on it to create a bond.... SBR has been out a lot of years as well and much better a product..
The old PVA IMO is just a tradesman's tale that has always been used because they have never had a failure, a bit like adding portland cement to skim or base coats to make it set faster and they have never had a problem with the 2 products reacting..( Until it does) :)
I know a couple plasterers and they don't use pva.. 1 uses sbr and the other uses some sovereign gear not sure on the name.. but i am just a tiler.. who am i to quote plastering work..:):)
johnryan
this might be helpful. dot and dab is page 18
Broken Link Removed
Reply to Dot & Dab PVA in the UK Tiling Forum area at TilersForums.com
I'm searching for 42 pieces of 12" x 12" Verde Alpi marble tiles. Preferably honed. 12" x 24"...
I'm Looking For This Tile Porcelanosa Town White Polish 595mm
I'm looking for a few Porcelanosa Town White Polish / Pulido floor tiles - badly laid in my new...
