Currently reading:
Decoupling membrane
Discuss Decoupling membrane in the Canada Tile Advice area at TilersForums.com.
L
Leory
Y
Not essential but i would. If you need to lift a tile to adjust the bed, it's far better if the mat is stuck down well!
Anhydrite floor? Sanded and vac'd? Moisture levels checked?
Yes anhydrite floor . Moisture levels checked with tramex in the room I'm starting in the levels were .8 in some areas where the screed was a bit thicker . Chose to use anhyfix in this room as tile masters said I could if the level was no more than 1 . Fingers crossed !
Sor
Sorry didn't answer some of your questions . I ground the floor with a diamond grinder and removed all laitance will Hoover again tomorrow before priming .
Ajax123
1,213
Lincolnshire
they are a good survey tool as they give you an indication of where the screed is wettest but are not accurate enough to give a proper reading and as we are dealing with very low moisture contents the inaccruacies are multiplied. a properly calibrated hygrometer used corredtly or better still a carbide bomb is the right tool.
L
Leory
Ok . Thankyou .
The screed has been laid 110days .
Didn't grind off laitance till plasterers
Had finished . Made them mix up outside . Underfloor has been on for 4 weeks . I am going to get started today using the anhyfix to bed the dura may .
On the other rooms where the screed is only 50mm thick and reading .2 on the tramex I am hoping to use cement adhesive after 3 coats of
Acrylic primer . Underfloor been off for over 48 hours
Reply to Decoupling membrane in the Canada Tile Advice area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which is very thick concrete. He wants electric underfloor heating but I'm concerned he'll lose too much...
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed most of our floor to accommodate tiling 800x800 porcelain over an uneven floor. The gap from defrac...
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber floor in our barn conversion. The area is large, 21m x 8m. Having spoken to various UFH suppliers I...
