Discuss Decoupler Mat Required? in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi, I am currently looking at tiling an area of 43sq.m. 25sq.m is on screed with wet system UFH incorporated, which was laid three months ago. The remaining 18sq.m is on a combination of concrete slab and 70mm screed. The tiles are large format 600 x 600 porcelain
I am considering whether a decoupling mat should be used to avoid any problems with settlement in the future or if a S1 flexible adhesive would be sufficient on it's own.
What are your thoughts?
judge
Agree with Gaz,also if both floor areas join you will need an expansion joint where they meet
Thanks for the advice. There is a step between the two floors, so no expansion joint required. Could anyone recommend a suitable decoupling mat and adhesive?
Kevbos
I would use a decoupling membrane ! Like durabase,!!
Reply to Decoupler Mat Required? in the DIY Tiling Forum area at TilersForums.com
Dawz84
