Discuss Decoupler Mat Required? in the DIY Tiling Forum area at TilersForums. USA and UK Tiling Forum
Hi, I am currently looking at tile an area of 43sq.m. 25sq.m is on screed with wet system UFH incorporated, which was laid three months ago. The remaining 18sq.m is on a combination of concrete slab and 70mm screed. The tiles are large format 600 x 600 porcelain
I am considering whether a decoupling mat should be used to avoid any problems with settlement in the future or if a S1 flexible https://www.tilersforums.com/forums/tile-adhesive/ would be sufficient on it's own.
What are your thoughts?
judge
Agree with Gaz,also if both floor areas join you will need an expansion joint where they meet
OP
F
Thanks for the advice. There is a step between the two floors, so no expansion joint required. Could anyone recommend a suitable decoupling mat and https://www.tilersforums.com/forums/tile-adhesive/?
OP
F
Thinking about this further, would it be possible to use a S2 https://www.tilersforums.com/forums/tile-adhesive/ and eliminate the decoupling mat altogether?
Kevbos
I would use a decoupling membrane ! Like durabase,!!
Reply to Decoupler Mat Required? in the DIY Tiling Forum area at TilersForums.com
05jtaylor
I've Disabled AdBlock
