stevee
i cut the face with 4" grinder on a workmate,i dont enjoy bending over either ,paid a handsome£5.70 for a cracking blade from machinemart
Blimey, some of you take risks using those small grinders.
Anyway, i have a bench wet saw that i use for virtually every precise cut. For sockets, i pencil the tile out first and cut the amount that my blade will allow along said drawn lines. My blase will just about go through the back of a 10mm tile before 'overcutting. After i have 'cut' my square (which is too small to fall out of the tile on it's own), i then wet cut across 45 degrees to the points of the square. By this time 6 cuts should have been done. You will then be able to tap the tile through the middle of the square, then tidy up inner edges manually.
I might sound a bit of a knob here, but i find that most precision cuts should always be done with water. Much kinder to the tile!
So would you mess about setting your saw up for 1 plunge cut..?
i always use angle grinder mark front cut to lines turn over finish off :8:
Most certainly mate.
I can cheat a little when it comes to filling the machine up though. I always keep a couple of bricks in the van, jack the back of the machine up so i only have to put half a bucket of water in!
Takes about a minute to set everything up, maybe 10 minutes to cut the tile.
A tip!!....Put the pump in a bucket of water for single quick cuts....then you don't have to worry about putting bricks under the legs..![]()
I do the bucket of water thing, keeps your pump clean. Do any of you guys put a drop or two of fairy liquid in? Keeps my hands nice and soft to.(Not)
