DHTiling
The use of a jigsaw for cutting a square section out of a tile ....kindly demonstrated by our very own Doug boardley.....cheers doug...
[yt]0i45Y1o-8Hs[/yt]
I think they're bosch, certainlt the bosch bayonet fittings,I get them from longhorn hardware, about the same price as wood blades, but as davy g says, no good for porc or floor tiles, great on trav, slate etc thoughNice one, Which blade are you using in the Jisaw Doug?
yeah i don't disagree, but doing it with jig saw you're not limited to squares/rectangles, but when you do squares you can get right in to the corner with jig saw,no need to trim corners outNice vid. never seen jigsaw used on ceramics before. Plunge cutting would still be quicker IMO.
but doing it with jig saw you're not limited to squares/rectangles, but when you do squares you can get right in to the corner with jig saw,no need to trim corners out![]()
