Discuss Concrete Blocks in the Australia Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
MTiler
Hi Peeps
Do concrete blocks vary in quality and which are the best type? I take it I should go for Dense Blocks?
I ask as I am revamping an old concrete spa bath. It has cantilevered seats which would be practically impossible to waterproof underneath let a lone tile. So I plan to block them off with concrete blocks.
Whats the best way to cut/shape them?
cheers
Sharon
Ajax123
Class a dense concrete blocks.
Spud
When I worked in Germany we would block up all our bath panels with 50mm gas ytong blocks they are lightweight and easy to cut, you can cut them with a masonry saw very similar to thermalight blocks ,if you are waterproofing them then they will work fine. As they are light weight they are very versatile too I would set them back at an angle to create a toe space
MTiler
Cheers Gary. Where do you get them from and what do you set them with? I was going to render the front of them before I waterproof the bath.
Spud
Builder depot in south gate should have them , the thinnest blocks here in the UK are 75mm you may have to use them
Reply to Concrete Blocks in the Australia Tiling Forum area at TilersForums.com
Lowpaul22
