Discuss Black limestone indoors in the Australia Tiling Forum area at TilersForums.com.
mrct
Just about to lay 70m2 black limestone indoors, read a lot of horror stories so just looking for an insight. The customer / stone supplier is supplying all sealers. I intend to seal prior to laying, fronts sides and backs. I intend to seal again prior grouting and after grouting.
The horror stories I've read on here are all about marks etc. is there anything I need to look out for ?
Cheers.
Lithofin BOB
508
Hampshire
Cheers.
I am concerned with the pre seal before installation , I know many guys do this , we/ I would never recommend this .I am more concerned with the suggested sealing of the back, I would never recommend this due to poss failure of bond. I have discussed this with all the larger manufactures and not one would recommend this with an impregnating sealer.
Are there possible primers for this?
Most of my problem floors are moisture related, a lot of the time with the darker stones ( basalt a real prob over the last two years). Although rapid setting is used, this is not rapid moisture release and in some cases moisture is trapped leaving white salt/ eff in the stones, some of these issues in some stones are not reversible. There are moisture crystallising adhesives these can shorten dry times before sealing but still have limits. I hope the guys will comment.
Generally I suggest to lay.
Release all moisture , when fully dry seal face and edge. 1-2 saturations depending on density and porosity
Curing time / min 12-24 hr for solvent
Test grout removal over sealed surface finish ,Grout
Once fully dry and all moisture gone seal again over all.
Note;I am not a fitter, just deal with problem floors.
Sure the guys will give you a full run through. I also look forward to the responses
mrct
Cheers for this, wasn't to sure about sealing the backs however with basalt I've heard bad things of trowl marks etc bleeding through as they were not sealed so I was a little worried about this on black limestone.
Think I'll go with sealing front and sides. Stone seller is providing the sealer.
Lithofin BOB
508
Hampshire
The black trowel marks coming up through ( water marking migrating from the adhesive) when a tile is removed on inspection ,the tile is often just placed upon the adhesive on the ridges , not 100 % bedded similar to dot and dab ( points of contact) so you get the moisture coming up as trowel marks, even worse if this is trapped by a pre seal.
Full bedding is key as always, no issues then with marking. sure the guys wil comment
jonnyc
Definitely use rapid set rather than normal set and we always back butter tiles as well.
bob
what do you think of the presealing of stone that one of our london stone companies carries out using stainstop.
Lithofin BOB
508
Hampshire
bob
Hi jonny,
Generally no, I would never recommend to pre seal prior to instalation , I know many fitters and contractors that do and a lot that have had no problems. Lots that do .There a few factors that we need to consider.
Density and porosity of different stones; stones drawing and Releasing / holding moisture at different rates, giving us patchy floors sometimes .
type and quality of sealing product used; what type of pre seal is used on these stones , sometimes water based will not bite us as much , ( still wouldn't recommend a pre seal)
application of the sealing product; after viewing stones being pre sealed , some times this will consist of a wipe over or a quick spray. Some are over sealed
Just as a note, if you guys get a pre sealed stone to fit , test that the pre seal is suitable and giving you full repellance and grout release, have had many issues with some pre sealed and guys getting bleed across a whole floor, when cleaning up grout .test on an unlaid tile.
colour of stone; coloured stones can be problematic too,
Whites and lights can water mark under the pre seal, certainly if not fully bedded, floors can look a lot darker ,white marbles often get odd tiles darker than the other often due to pre seal or sealing to quickly after install.
The darker stone will show a white cloudiness / patchy poss salt or dead seal, if salts ,this can be difficult sometimes impossible to remove , I had 400 Sqm basalt ripped up 4-5 weeks ago due to pre seal , gutted -beautifully laid
adhesive used; which to use , rapid ,normal, cystalizing .rapid setting is what you guys advise but I still have a lot that use the slow, this moisture can linger under the seal Causing above issues .
Rapid setting yes!! But it's not rapid moisture release,
Is it only moisture from adhesive we need to be concerned about; consider screeds , are they really dry ( the builder says it is!!!!!) also self levellers , look how much water we put into these , it all needs to release or can be trapped under a pre seal.
I am Sure there are a few more reasons,you know I get a bit negative some times , but have had three floors this week with pre seal issues , get 20-25 calls a day with problem floor as you know jonny and most are moisture related. Of Course the conversation starts " your seals done this to my floor"
Not the seal, now "when was it applied"
So to keep it short !! Lol. No, i have concerns
Reply to Black limestone indoors in the Australia Tiling Forum area at TilersForums.com
  • Sticky
