Bathroom Floor
P
PaulR
I've used this forum about 10 months ago to sort out my shower and bathroom walls, so I'm hoping you'll point me in the right direction now with the floor
I have some good quality ceramic floor tiles already in place on the bathroom floor, however as I found with the walls, the grout used is
a) rubbish, not fleixbile and not waterproof
b) gradually breaking down and coming away, so much so I regularly pick bits up and out
My question is, given that I've not had leakage problems or stability problems, should I pick out all the crap grout and regrout using a good quality flexible waterproof grout, of which I know the stuff I used on the walls of the shower is good and I can probably have a bash myself, or realistically is there more needed here!
thanks
hi Paul
Were the floor tiles already down or did you lay them yourself? If you laid them yourself, do you remember what grout you used?
If you didn't lay the tiles, you can always re-grout, opting for a flexible grout. It can be hard work to pull all the existing grout out without damaging the tiles, but if you're careful enough, it could be a days work. So long as the floor tiles are stuck solid, re-grouting is fairly straightforward.
I'd say have a bash. I got into tiling by re-grouting a kitchen and a bathroom, and then occasionally had tiles ping off mid way through the grout raking!
:thumbsup:
For grout to be popping out you must have excessive deflection or incorrect grout was used...
Can you tell us what was used to sheet the floor and what grout was used..?
Hi
Already laid, in a loft conversion.
Having experienced the previous problems I had with same tiles and same grout on the walls, I'm going to guess a normal non flexible grout was used
The tiles all seem very solid and I feel like I can rake them quite easily. The grout I want to use is called
Mapei UltraColor Plus Flexible Grout
also, turns out he tiles are porcelian if that makes any difference!!!
Bathroom Floor
Bathroom Tiling Advice
Unsolved
PaulR,
david campbell,
PaulR,
david campbell,
