Bath panel????
What about wedging it in with expanded polyethylene foam 5mm or 8mm. That wouldn't need cutting. It would just slide out... Just an idea
I just wedge and Silicon.
Personally, if its done right it shouldnt need access.
I read a thread on swedish mikes forum, that man is loon balls, he says he would recommend EVERY water joint to have a access panel , EVERYWHERE , imagine all over your house, access panels in ceilings, walls and floors , unless i read it wrong this is what i thought he was saying, i think rob(CR) was having a bit of a 'debate' on it
As a human, SwedishMike is a complete goon that would benefit from a good hiding. However, I live in Norway specialising in wetrooms, and if regulations are same in Sweden as they are here, he's right. Every water joint inside a wall must have an inspection hatch, end of story.
And if you see the plumbing in some of the new build now every joint should just be left visible!!!!!
Bath panel????
Spare Tool,
widler,
Spare Tool,
widler,
