Bad job or unavoidable?
Hi,
Currently getting a new bathroom fitted with metro tiles. The tiler is back today to finish off grouting and laying the floor tiles. I've gone in this morning to check the last 2 days work (having been busy working myself so couldn't check before now) and I am pretty unhappy with the way the tiles have been laid very unevenly in my opinion. Is this acceptable or unavoidable for some reason? Thanks.
Just spoke to the guy and this is what he said. Unfortunately didn't let me know otherwise I would have got it replastered. It is an old, terraced, edwardian house so doesn't help either!
The center joints look to be in line so definitely walls are out as is
frame which you couldn’t really do anything about…. Grout in white will help blend in.
Two things you need to do:
1 . Hold a (decent length) level (vertically) against the vertical edge of one tile to show how aligned the vertical edges of the tiles are.
2. Hold a (decent length) level vertically against the corners of your walls and photograph the bubble to show how plumb your walls are.
It's hard to tell from the photos you posted, but it does look to me like the tiles are not vertically aligned (I held a straight edge rule on one tile edge and the tiles are out of plumb on all your photos so it's suspicious).... However, it could be a combination of both as tiles are way out looking at your photos.
If your walls really are that far out, that should have been mentioned to you (if the tradesman was any good) before the job was started so you were aware of the problem --- it could have been easily rectified by overboarding. Another potential issue is that if your walls are that far out, a lot of not-very-good tilers will start tiling from one corner of the room relying on the corner edge as their plumb line. Problem is, if that's out (and it usually is) the tiles will never be properly vertically aligned - that might have been done in your case as you've not photographed all corners.
To me it looks like !what happens all too often , a plumber has also been involved in the new bathroom , as capped pipes in picture , it's very easy for criticism, but we don't know budgets etc etc !! Is a builder involved , it's not right that walls are wrong , but who was responsible for preparation??
Spauser90,
Kevbos,
Spauser90,
Kevbos,
