Hello,
I am pretty new to this forum and would like some help please on laying sandstone indoors. I’ve read up everything I can find that looks relevant first so as not to waste your time :smilewinkgrin:
I have a 3.2m diameter circular floor area with anhydrite screed finish and am a laying Bradstone natural sandstone (pre-cut) circle kit (approx. 20mm thick).
The screed has been sanded to remove laitance and is flat. There is very LOW temperature (approx. 35 deg C) warm water underfloor heating laid below the screed.
Do I need to lay a decoupling mat?
What adhesive would you recommend? I do not need to make up any height.
I plan to seal the stones before laying with Lithofin Stain Stop until the stones are saturated. Does anyone have alternative recommendations?
What grout works well with sandstone? The joint width is 10-15mm on these kits as they are really for outdoors. This seems very wide to me.
Are there any other pitfalls I should be aware of please?
Thank you in advance.
Frances
Frances
