advice fixing natural stone tiles
boxhead
im after some advice lads.on short notice ive been asked by a builder to fix some large natural stone tiles on a wall. this is my first stone job.the tiles are 12mm thick and 400x200. they are quite heavy, some will be upside down under a shelf. 1; do you recommend a 6mm or 10mm trowel. 2; they are dusty, should i back skim them. 3; they are almost white,do i seal them, if so before grouting them and after.and finaly 4; what size grout spacer would you advise for the job.would appriciate the help as i start these in the morning.ta:huh2:
1) Solid bed fix 8mm trowel .
2) Flat back on sponge wiped tile.
3) Seal them before you touch them! Seal them again before grouting - if clean and dry. Seal again if required after grouting and only if clean.
4) IMO 3mm.
Check what the wall surface is before fixing - weight!
Use a powdered fast set WHITE adhesive.
Timeless John.
i agree with john on most points i think the spacer size comes down to a couple of things
do the tiles have a rectified edge or are they tumbled edge ?
if rectified i would use 2 or 3 mm spacers
also ask the customer what size joint they want as they may have seen them fitted somewhere and they already have a look they are looking for
i would use a slower setting adhesive if you haven't done stone before but definitely a powdered one
and definitely check what surface you are fitting on there is a lot of weight there
oh and good luck and take your time :thumbsup:
1. 10mm
2. yes, it only helps
3. depend what kind of stone
4. 1-2 mm
5. if you don't have enough experience with stone, never use fast set, always use slow set flexible (in your case white) adhesive
timeless john due to very inclimate weather it is very awkward to seal due to space.do you think if i sponge them vigerously as i fit them ,i could seal when fitted before i grout.:thumbsup:
boxhead,
beanz,
boxhead,
beanz,
