Discuss Adhesive thickness in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi all, going to be putting some 600 x 300 (9mm) porcelain tiles up on a jackoboard tanked shower wall what size notched trowel do I need and what would the usual grout line size be, thanks
Spare Tool
Personally would use a 10mm square notch trowel, backbutter/skim the tiles also before fixing, standard on walls is a 2mm spacer but some tiles can be a bit sizey so you may need 3mm and a pack of wedges to give yourself some wiggle room..check your tiles before starting.
Reply to Adhesive thickness in the Adhesive and Grout area at TilersForums.com
mcgtech
