Discuss Epoxy grout and grout floats . in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
I haven't done epoxy grout for a number of years and the last time I did I used one of those heavy solid grout floats. Now My question is with the improvements in epoxy grout is it still necessary to use this sort of float or can a standard grout float be used .
Q
Qwerty
You can easily use a standard float now. It floats just fine and I've found the epoxy floats too hard with the modern epoxys
GoneGuy
I’ve been using the Kerakoll fugalite bio with the Kerakoll float and seems ok
H
hmtiling
Been doing a lot of fugalite recently. Been using my raimondi epoxy float though I imagine a standard float would be OK.
MTiler
Raimondi and Kerakoll epoxy floats are nice and light weight to use. A standard float isnt stiff enough to clean off excess epoxy
Q
Qwerty
Maybe not for mosaics but I've found my standard Rubi float more than adequate at spreading and cleaning off excess epoxy for both Fugalite bio and Kerapoxy
Reply to Epoxy grout and grout floats . in the Adhesive and Grout area at TilersForums.com
Lowpaul22
