Discuss What's the best course of action for this wall? in the Tiling Courses area at TilersForums.com.
Good evening all. Removed some tiles in bathroom and damaged the wall. Plaster has come off, underneath I think its bonding plaster? Haven't a clue.
What would be the best repair method for the wall, also can I installHardiebacker without plastering the wall after the repair?
Will be installing mosaic tiles.
Any help is appreciated.
If you are installing mosaics the wall needs to be perfect , knock off and reboard, I wouldn’t bother with hardie , its a pain imo and plasterboard is perfect, if its in a wet room , tank it
not looking to knock back. Its too much work and the wall is where a window and toilet is. :(
Just want wall as flat as possible to put some type of backing board over.
Do you recommend multifinish over surface or another product?
Tile Fix Direct
TF Official Sponsor
153
733
Aldershot
The trouble with any plaster finish is that the surface flatness is unlikely to be good enough for mosaics. Another method is to dry line with Orbry board with supplemental Orbry Spanker mechanical fixings. Boards are waterproof so use waterproof tape on joint for wet room. Boards incorporate insulation so reduces risk of condensation (always include forced ventilation in bathroom) and mouldy grout.
https://www.tilefixdirect.com/pdf/Orbry-Spanker-Dowel-Fixing-Guide.pdf
Orbry Board - https://www.tilefixdirect.com/product/Orbry-Insulated-Backer-Board
Is the bonding sound? If you have a subdue and reboard are you happy with the extra wall thickness around window ?
As shown in the pictures its pretty much just parts that have come off and texture in some places so not smooth. Was thinking of filling damage then getting flat as possible, then 6mm backerboard. Just need to know what product to fill holes and over the bonding to get smooth as possible.
Thanks already have some prowarm boards. Is yours better?
Boggs
1,118
Uk
Had two walls like this on Monday, also was short on space due to architraves that could not be removed.
I primed walls with TM Prime Plus, then using my tiger trowel combed TM Ultimate over walls and stuck on 6mm Delta Board and made sure they were flat with a straight edge.
Next day screwed through them using 35mm washers and screws every 200mm, tanked one side as it was in a wet area.
Sorted.
Sorted.
Will be doing this after filling a few of the deeper gouges in the damaged bonding coat with Gyproc Easi-Fill.
Reply to What's the best course of action for this wall? in the Tiling Courses area at TilersForums.com
  • Sticky
  • Question
