Discuss New screed meets old screeds in the Canada Tile Advice area at TilersForums.com.
Cranbrook
598
Pontypridd, South Wales
Unusual (for me) job I've been to quote for this week where the customer has had a large extension added to a bungalow and has made a large open plan kitchen by utilising a hefty RSJ.. customer has also had another extension to the side to make a smaller utility room.. anyway, the thing is, the new screed in the large extension is a pumped AH and the smaller extending is a traditional sand cement screed. The existing screed is a sand cement that was previously tiled.
My question is, what would everyone do in this kind of instance?
P.s, tiles are 60 by 60 polished porcelain the customer tells me
acaciaguy
558
Warwickshire
Is it pumped anhydrite ?
If so it’s a more complex / modern version of sand and cement - quicker setting and other inproved properties (apparently)
Is the floor level across the different area?
Cranbrook
598
I didn't have my laser to do a thorough inspection, but where tiles had been removed from the existing screed, there is definitely repair work to be done, so I'm leaning towards latexing the whole lot.. thoughts?
L
LM
Anhydrite mate
Your’e gonna have to treat both sections as two separate floors, prepare and level accordingly then have a soft expansion joint between the two areas.
acaciaguy
558
Warwickshire
Lee Mac. Is there a slc or similar system that can be used on both surfaces to turn them in to “one” for tile fixing? Just a thought. I appreciate this may change heights of floors.
Cranbrook
598
This was my train of thought.. I'd like to avoid an unsightly expansion joint as it will ruin the look of the kitchen diner imo
Reply to New screed meets old screeds in the Canada Tile Advice area at TilersForums.com
