The blades are very good.
I need to try them for longer.
but you, are not you a plumber?
I have not understood yet .... 🙁
one day you're holding the pipes
the other one is holding the saw dqa carpenter and another the tiles ...
I’m a Bathroom Installer. I Install complete Bathrooms.
The biggest part of my job is Tiling.
I am a trained Plumber though which is where it began.
I mainly do Bathroom tiling and know my limits with what I can do. For example I wouldn’t tackle a huge floor in a kitchen.
If it’s a problem, I’m more than happy to have the professional Tiler title taken away. It honestly doesn’t affect me other than the use an area of the forum.
I’m not sure where this has come from, first I’m being told I should learn to write then the follow up is asking what I do. :tearsofjoy:
Have a good evening.
ahah, I'm just kidding you .
There is no problem Luigi 🙂
problem, I mounted the blade on the Bosch, it is hard to get it into the blade holder.
you must tighten the blade with the key,
with Hitachi it was ok
I tried it last night on my Bosch cordless. Also tried on my flex. Both fit ok. It’s a little bit tighter on the flex.
GoneGuy,
demi34,
GoneGuy,
demi34,
