H
hmtiling
I thought coverlam was grespania and I found them to be terribleVery high quality too. Of all the thin porcelain I've worked with, Porcel-thin and Grespania's Laminam are the best in my experience.
Discuss Thin porcelain suppliers in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
The coverlam I've used has been great. Cuts well, edges well and whilst I don't think the designs are as good as others, quality has been good for working with.I thought coverlam was grespania and I found them to be terrible
Only used the 5.5mm stuff and it was bowed and tensioned. I had a nightmare with it. L cuts had to be drilled with a 25mm bit as anything smaller they'd just go on first pass with the grinder. It was not much fun at allThe coverlam I've used has been great. Cuts well, edges well and whilst I don't think the designs are as good as others, quality has been good for working with.
What issues have you had?
Bad setting out if you need a cut that sizeThis is the 3.2 x 1.6 x 6mm Florim Simon was talking about.
Its actually a really nice piece.
Matt on floor, polished on the walls. (Eventually )
This was satisfying, 3.2m long, 25mm wide, scribed and snapped in one piece.
View attachment 100038 View attachment 100039 View attachment 100040
Reply to Thin porcelain suppliers in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
