Always done our grinding outside. Looking now for the best grinder attachment for a vac. Need to see the blade cutting . Any ideas ?
I use one of these chinese types - there is also one that has a foot/frame a little like a hand circular saw which I hope come through on the first link as some items at the lower part of the page. I have never found a 'branded' one (be interested if anyone knows to one). They are pretty good.
Dust Shroud Kit Dry Grinding Clear Dust Cover for 4 Inch 5 Inch Angle Grinder | eBay - https://www.ebay.co.uk/i/272961830419?chn=ps&dispItem=1&adgroupid=47476323250&rlsatarget=pla-414281527381&abcId=1133916&adtype=pla&merchantid=113718614&poi=&googleloc=9046675&device=c&campaignid=1058842219&crdt=0
4"/ 5" Angle Hand Grinder Dry Grinding Dust Shroud Cover Clear Dust Shroud Kit | eBay - https://www.ebay.co.uk/itm/4-5-Angle-Hand-Grinder-Dry-Grinding-Dust-Shroud-Cover-Clear-Dust-Shroud-Kit/112664512522?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20160908110712%26meid%3Db0b81159303a41149443867c179436aa%26pid%3D100677%26rk%3D3%26rkt%3D19%26sd%3D272961830419%26itm%3D112664512522&_trksid=p2385738.c100677.m4598
My Dewalt brushless 125mm 18v grinder is a little more power than my Hitachi corded grinder (industrial version) and my 54v flexvolt is a lot more powerful at 1700W output. This has taken over jobs of the 9" (not all).
Large blades can be used (180mm not recommended for safety reasons but it get used like this) - 150mm discs / guard compatible. Over 4 times the power of the older 18v - batteries require a mortgage (or two).
I do not understand what you wrote....
how long did it take me to mount it all?
I took the table 6 months ago, I put only the extensions.
I got the raizor 3 months ago
assembly of the grinder on the power, half an hour at the most ...
GoneGuy,
demi34,
GoneGuy,
demi34,
