Julian 'Farmer' Bonsall
Came across this while looking for something else. I hadn't entirely appreciated the state of cure effect on tile coverage.
I spent some time playing with grouting systems for large structures (a little like large radio telescopes) mainly with BASF and concrete systems for similar structures.
I was looking some advice on how lono before grouting I'm hearing 24 hours and also hearing you can do it after 3 to 4 hours could someone advise me please thanks
Generally speaking yes, but atmospheric conditions and substrate also play a part.So after those times its ok to grout
You hear lots of things over the years.I hear sometimes tilers grout walls straight after finishing the tiles is this wrong are you better to come back the next day
No problem.Thanks very much for taking the time to reply really appreciate it thanks again
That sounds a question for a Concrete technologist. I have some knowledge but remember in struggling with a small disc and a slab of clay at the momentInteresting......,
I also currently trying to learn how to braid paracord and make shock cord splices and having as much look as sanding tiles
Does this mean you can you could explain the chemical reaction between Portland cement and aluminium?
Sorry Plan Tec I had completely missed this post of yours - personally I think his tamping stick is patentable and needs branding. The chap with the 'adhesive hands' is a brave one 🙂If you want another giggle
From the manual.
Concrete shall not come in contact with any
aluminum during conveying and placing
operations.
Aluminum Frames in Masonry Walls - http://www.cement.org/learn/materials-applications/masonry/masonry-construction/aluminum-frames-in-masonry-walls
