Levelling clips how many?
Tommythetiler80
Evening good people, I’ll soon be fixing some large porcelain tiles 600 x 1200s to an area of about 80 Sqmt. My question is how many of both clips and wedges would one order for such an area?
Also im planning on using a 3mm joint throughout so is it recommended that I should buy 1mm clips for ease of removal?
Thanks in advance.
Tommy assuming you’re a professional tiler then my advice would be to order 500 wedges and 2000 clips to start with. Once you’ve tiled a floor with clips I doubt you’ll tile another notable one without them so any that you have left over won’t be there for long. I’d order 1.5mm or 2mm thick clips to give that extra strength and they’d still be fine to pull out as you’re using a 3mm spacer.
Thanks Lee yes I is ...... never fixed tiles this big before so I thought I’d give the clips a go... maybe I’m a bit behind the times but it’s never too late to try something new
Tommythetiler80,
Andy Tiler,
Tommythetiler80,
Andy Tiler,
