Discuss 1 way fall shower former in the Tanking and Wetrooms Forum area at TilersForums.com.
1sandyh
I'm after a wetroom former for a 1 way fall 1500 wide x 900/1000 out
Linear tray to run along the 1500 side
Cheapest quote I've had is Novellini at £650+vat!!!
Surely there must be a cheaper alternative?
If not, would it be possible to build this myself, if so how? Dukkaboards?
Have spent hours ringing around & googling. No joy, please help!
Bill
Yes you can build them yourself... but you can also buy two wedge boards ( that is what they call them) and join them together to make the size you want
1sandyh
Cheers Tom was hoping you'd be along!
What materials do you use to make your own?
It's for a timber deck
Bill
I would use the wedge shaped linear tray formers, sat (glued) on to 18mm wbp ply. You need to establish a FFL so that you can set your base height level to incorporate the tiles and adhesive.
You could just use flat 20mm insulation boards and create your own falls using tile adhesive, sloped towards the drain but this is quite difficult to do for a novice.
1sandyh
Got you. I can't find a pre made former that's 1500x900/1000 - apart from Novellini which is over £700. Drain needs to be on the long 1500 side
Any ideas? Thanks
Bill
Any ideas? Thanks
yes buy 2 or 3 0f the slimmer ones and lay them side by side - taped with tanking tape and cut to the desired length.
1sandyh
Sorry just to be clear, buy 2 of the one way formers & join them? Any you particularly recommend that don't break the bank?!
Bill
To be fair... what you are wanting to do is quite a unique job............ why do you think that should be cheap?
1sandyh
Fair point. Just don't want to spend a fortune if there are alternative/more cost effective ways that's all.
So 2/3 formers joined together?
Reply to 1 way fall shower former in the Tanking and Wetrooms Forum area at TilersForums.com
Teejay
