Discuss Loose tile over underfloor heating in the Canada Tile Advice area at TilersForums.com.
Jennifer Robyn
We have prowarm electric mat laid on concrete base. Ceramic tiles 600x 150 mm laid on top. One tile makes a ‘cracking’ noise when walked on; assume this is a sign it is loose. The grout is still intact.
Is there any solution that doesn’t involve ripping my hall floor up.
Q
Qwerty
I would suggest carefully cutting that one tile out and gently break it up to avoid damaging the UFH. If it was a professional, can they not return to rectify?
Jennifer Robyn
Unfortunately I doubt they could. We will try to contact them, but need a plan B.
Q
Qwerty
Carefully rake out as much grout as you can, then cut the tile from corner to corner using an angle grinder, so a 'x' is made in the tile. You need to make sure that you don't cut deeper than the depth of the tile or you could cut the UFH.
Have you considered offering the job to a pro on this forum?
Jennifer Robyn
Yes
Yes, think that’s the best option. I just needed to find out the answer wasn’t ‘ rip the whole floor up’!
Reply to Loose tile over underfloor heating in the Canada Tile Advice area at TilersForums.com
