Yes Lee, I think your right. Gonna contact pro tiler tools see what they can do for me.
Cheers for all your wisdom!
Are you sure you didn't buy a 14M wheel which is designed for mosaics?sigma 3c2
Good call! Think maybe I did! That would explain a lot! Have to be more careful in future! Maybe an age thing? You are the sigma man 🙂Are you sure you didn't buy a 14M wheel which is designed for mosaics?
I can't explain this 🙁, perhaps I have been lucky so far? 🙂I'm not convinced of this......
I tried titanium, 15x15 tile very hard, after three cuts, I still put the old wheel.
I may be wrong, but the wheels in titanium seem an unnecessary expense .. 🙂
The standard wheel should be more than fine for anything you may be doing, just stick with that. 🙂Good call! Think maybe I did! That would explain a lot! Have to be more careful in future! Maybe an age thing? You are the sigma man 🙂
All my Sigmas have the original wheels in, and only a couple of months ago did I have to change a wheel in my 3CM (daily cutter) after approx 4yrs almost daily use.I'm not convinced of this......
same,All my Sigmas have the original wheels in, and only a couple of months ago did I have to change a wheel in my 3CM (daily cutter) after approx 4yrs almost daily use.
I suspect there is a particular reason for the titanium wheel, but stumped if I know!
That's what I said earliersame,
is only coated titanium.
I think it is just to increase the duration.
I repeated what you have said?That's what I said earlier
The titanium are more expensive as they are a better wheel, are more durable and last longer,
