dot and dab
diamondtiles
I came across a tiler the other day when working on site and he was laying wall tiles using the dot and dab technique - if you can call it a technique that is!!!!!!!
Surely this cannot be right???
Must be a rogue tiler???
Anyone got any thoughts on this ???
dot and dab, (known as spot fixing method), is not recognised within the industry. More often than not it leads to failure.....Gaz
Yet on a regular basis we remove perfectly sound tiles secured by the old fashioned method of spot fixing....... strange times we live in.
tiler
spot fixing was common place back in the sixty /seventy's when adhesive was just coming in
in fact Richarfix (the 1st wall adhesive used in Manchester i believe ) recommended the methered
some of the jobs i did using spot fixing are still there and looking good after 40 odd years ,and im not taking of the odd bathroom
how times have changed
Maybe it is because modern houses are built using moisture sensitive materials like plasterboard now. Back in the old days the were brick/block/concrete, neither were showers very popular then. Certainly not power showers.
aye thats one of the reasons no doubt although back in them days i didn't work on houses
serrated trowels not being invented could have something to do with it would,nt you say
Where would all the marketing people be now if it had carried on, you cant really write cutting edge bal literature on how spotting is the future can you :lol:
tiler
dot and dab
diamondtiles,
Qwerty,
diamondtiles,
Qwerty,
