Discuss White grout that looks grubby after a few years... in the DIY Tiling Forum area at TilersForums.com.
K
KateJ
I hear white grout looks great at first but soon starts to look shabby - can I prevent this from the start using a sealant of some kind?
Dan
Admin
1,318
Staffordshire, UK
Use a good grout and wash off well often. In shower areas its always body fats and salts so a good cleaner used often prevents it. Even if it's sealed it can happen still as it's on the surface of the grout usually.
Rich Midge
598
Liverpool
As above. Grouts have improved tremendously over the years, go for a modified professional grout and allow it plenty of time to dry before putting into use (at least 3 days). Rinse and dry shower areas after use.
Tile Shop
LOL
Tile Shop
Anyway, back to the thread.
Impish's idea of epoxy, probably not simple, but is the belts and braces solution. Just stiffer and harder to use.
Another option, use dark grout. It'll hide discolouration, but will highlight any flaws in your tiling....... if there are any ;)
Cement based white will discolour. Its unavoidable, but you can prolong the whiteness. As above there are sealers that can be used like the LTP Grout and tile protector spray, or the Sealguard spray. But would also help if you had a good quality grout from the off, like Mapei's Ultracolour Plus, which has a built in repellent which albeit not perfect, does help. but combined with the spray should make it much easier to keep clean.
When it does eventually go grotty, @Lee@TileTown has a nifty little colour reviver which you simply paint over the joints. but it'll be months down the line that you'll need to consider that, providing you don't cut corners and do the grouting properly.
Reply to White grout that looks grubby after a few years... in the DIY Tiling Forum area at TilersForums.com
