Discuss Awkward wetroom floor. in the Canada Tile Advice area at TilersForums.com.
JMC tiling
548
hemel hempstead
Evening all,
got a job to start next week with a wetroom floor that is gonna be a bit of a challenge.
Situation is as follows:
A suspended floor with very little deflection if any.
1600x800 former tray going in that is going to be tiled in 16mm thick encaustic cement tiles envelope cut. these are going to run up the wall (on the 800mm side) and run along the floor to the end of the wall following this line. You following so far?
the rest of the floor (about another 6 sqr mtrs is to be tiled in 10mm thick 600x300 porcelain that will have to be finished at the same height as the encaustics. there is underfloor heating going underneath these and the encaustic tiles that are not on the former tray.
My plan was to install tray 32mm-35mm higher then existing floor boards, then tile backer board rest of room in 10mm backer board. then on the porcelain side install another 6mm backer board to allow for thickness difference in tiles. then lay the underfloor heating that will have to step down (chase in to backer board) to go under the encaustics. Then I want to put levelling compound over the wires which by the looks of it will have to be done in 2 stages: first, shutter in the porcelain side (highest side at the moment) and level over wires, then when that's set, go over the wires on the encaustic side using screws to get my exact height as can't afford this to be too high.
I'm not very good with computers otherwise I would try to do some sort of diagram to show what the situation is, maybe someone could advise.
Anyway my biggest concerns are:
1. Getting the heights right so the porcelain and encaustics end up being installed at the same height.
2. With the underfloor heating, different tiles and different thickness of substrates, what are the chances of any potential problems and are there any other possible ways in which you guys would tackle this?
Cheers.
JMC tiling
548
hemel hempstead
these quick scribbles might help to explain a bit. If anyone who has had more experience then me with encaustics can advise on if these are actually suitable for a wet area that would be much appreciated.
Spare Tool
Evening all,
Cheers.
Less I'm missing something here, if you install the tray 32mm higher than existing floorboards then 16mm ins board rest of room this still gives you a 16mm step up to the tray, even with ufh and SLC say to a total of 10mm, the porc side still going to be 6mm lower instead of higher...no??
Time's Ran Out
I'd check with the supplier, they will be ok for a bathroom floor but to be cut to a former and on the wall ( weight issues aside ) I would not recommend such a porous tile even sealed as moisture will lie on the surface, get between the joints and stain the tile.
JMC tiling
548
hemel hempstead
yeah sorry, i'm confusing myself! looking at more like 16-20mm depending on UFH thickness
JMC tiling
548
hemel hempstead
I'll ring them tomorrow, cheers.
JMC tiling
548
hemel hempstead
And weight
will be fine a mechanically fixing Tile backer boards
Reply to Awkward wetroom floor. in the Canada Tile Advice area at TilersForums.com
