Discuss Do you use foam edging strips for SLC? in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
McLovin
I have never used foam edging strips with self levelling compounds. Installing UFH tomorrow.
Its been a while since i SLC so thought id watch a few videos as a refresher. Everyone seems to being using foam strips. Is this the done thing?
McLovin
Where do you get your perimeter foam strips from out of interest. Im going to need to pick some up in the morning? I was considering using off cuts of warmup board but its 10mm and could be costly if there are not enough off cuts.
McLovin
expanding foam or cut down XP-PRO insulation boards for me
Its going to have to be foam I think. Would this be? ok http://www.NoLinksToThis/p/no-nonse...ml/75470#product_additional_details_container
5mm round the edges sound ok? I'll use off cuts of board if I have enough.
McLovin
Foam it is I think. I'll get some strips in for next time.
I'll put 10mil around the permitter. Should do the job
Using 10mil warmup board buddy.
J Sid
off cuts of the warmup boards can be cut and stuck to wall and cut of after the leveller is dry
Reply to Do you use foam edging strips for SLC? in the Canada area at TilersForums.com
Lowpaul22
