Discuss Kerakoll Fugalite Eco :) in the Tile Adhesive and Grout Advice area at TilersForums.com.
MTiler
I work with Epoxy grout a lot and hate the stuff, doesnt help Im sensitive to it but its a pig to clean.
This week I finally got a chance to try out Kerakolls Fugalite Eco epoxy grout, or liquid ceramic as they call it.
Its the Dogs Danglies and stupidly easy to clean with the help of their Fuga Wash, even on mirrored mosaics. No need for emulsifying pads :).
Ive only used their Transparent grout so far (with silver glitter) so hoping their coloured grouts are as easy to clean too.
MTiler
It's OK. Smells less than usual and nice and soft to use but i found the oily residue very difficult to get off polished porcelain. Easy to clean off mosaics and anything textured though.
yeah it does have that oily look to it when applying. Did you use the Fuga Wash in the water when washing off grout, and then the Fuga Soap to wash off any dried residue when the grout had dried? I use two sponges with each tub.
I was working on mirrored mosaics and was amazed it didnt leave any residue after just using the Fuga Wash in the water. I thought it was going to be a nightmare. Ive yet to give it a wash down with the Fuga Soap.
I had fuga wash in my clean up water but no soap. Tried it since but tbh didn't see much improvement. I tend to do my final residue clean up the next day using fila graffitti remover.
MTiler
How does it compare to the bisazza fil gel?
Hell of a lot easier to clean and apply. You dont need to use any white pads with Fugalite. Its better than all the epoxy grouts Ive worked with, even the hybrid by Ardex which I didnt like at all.
I was using it last week in the hot weather and it didnt seem to have any effect on it, it stayed the same consistancy through out application. I think the only time it could be a bit of a pain is using it on ceilings, as its quite loose.
I have only used the Transparent, I assume the colours will be just the same.
It can also be used as an adhesive.
Simons70
763
Luton
Have you try to use the Heat Gun for see if can be easy to replace?
MTiler
This grout has been spec'd on my job next week and the only thing I cant find any info on is, how long after application do I wash off? The tiles are porcelain and there is a tumbled travertine mosaic border if that information helps. Thanks. @MissTiler
As soon as youve applied the tub clean it off. I didnt need to use white emulsifying pads. I was using the translucent grout with glitter, perhaps the coloured grouts might need white pads in the cleaning process.I just used a half decent sponge and sponge cloths. A capful of Wash goes in water to clean it. When its dry use the Soap to clean of any residue. I couldnt believe how easy it was to clean. I used it on these mirror mosaics and there wasnt any smudging after washing it down.
Still need to wear Nitrile gloves etc.with it.
Sorry just realised Ive already posted this pic :)
Reply to Kerakoll Fugalite Eco :) in the Tile Adhesive and Grout Advice area at TilersForums.com
I was really worried a few months back, epoxy grout to be used on 2 bathroom floors. After a bit...
Rob Z
R
R
Hello all, I put up a post a while ago on grouting (see link below). To most pro tilers on here...
16K
Firstly, a big thanks to Cliff Anger & Karl at Mapei for getting the shiny stuff to me! Now the...
28K
P
EDIT 12/2009: Mapei Epoxy Grout is probably easier to use I have benefitted from many of the...
37K
Tile Adhesive Trending Topics
Tilers Forums on FB
