Ufh Cable Might Be Damaged.
Sean Kelly
Today I had to replace a cracked tile.
The customer said there was UFH under the tiles.
I carefully smashed the tile out and had to excavate the adhesive from around the cable. I slightly nicked the casing from around the cable but covered it up with insulating tape to protect it against moisture
Before I started I asked the question about SLC over the cable. Yes, there was SLC said the customer. I did warn her that the cable could be damaged if it was not protected.
When I removed the thermostat I found that there 3 mats attached to it. I did a reading and got 16.9 off my multimeter. There was no room to separate the individual cables to test them.
The question is: If one of the mats (the one I nicked) was faulty, would I still get a reading off the multimeter?
I have no idea the size of the individual mats and I haven't the foggiest idea of what readings they should have.
You may find you'll have to isolate each individual Matt and take individual readings.
If that's a warm up cable their helpline is very good in my experience Sean
Is that whole floor covered in tape Sean?
Thats what i thought.
I can only guess that the whole floor is just like pic 1 above. Im surprised it hasn't already failed as there is trapped air between the cable and the tape.
I've suggested she turn on the mat in a couple of weeks to test it out.
I'd be more concerned about the tiles failing mate.
If that whole floor is taped you're relying on the tape staying firmly adhered to the floor.
If the tape fails, the floor fails!
Prob why tile cracked in first place.
Oh, The tiles have been down for years.
Somebody dropped a glass on the tile.
The tiles are hollow all over the place!
I was lucky that I only had to replace 1 tile. The others will go soon enough. The grout is cracked everywhere.
I wonder why?
haha
Not looking good ! That tape is no good at all, quote them for renewing it all. Whenever I'm asked to repair a tile or remove one over wires, I always explain its a risk and I can't guarantee the wires not getting damaged.
Did you try just turning it on before you retiled? I doubt a slight nick would be much prob , as I recall Devimat uses a kevlar coating so its pretty tough stuff in general.
Diggy
Diggy
I thought about that, but because the cable was exposed I thought I had better not. It's a conservatory attached to a room. About 40sqm.
I did explain about the hollow tiles and the chance that the UFH may not work afterwards. They still have 2 other mats!
I just nicked the cable and got to a silver wire..........It was the one of the very last bits of adhesive I was chipping out.
If it's like the cables I've used the heating cable(s) are in the centre surrounded by an insulator, around this is an earth braid and then the final outer insulator. If you have just nicked the outer insulator then you may have only just exposed a bit of the earth braid which I would think can just be recovered with insulating tape. However if you have cut deeper and reached the inner heating cable(s) then this will be more of a problem and a repair kit will be required (usually quite cheap) but this probably needs to be fitted by a certified electrician. Always check the resistance between the heater wires and the earth, it should be open circuit otherwise you have a problem. Please check with the tech help of the wire manufacturer, my notes are just to help understand the likely construction.
In addition to the no SLC I would inform the customer about the dubious use of tape and the poor fixing which looks from the photo to be dot and dab over a thin notched bed of adhesive rather than solid bed.
Sean Kelly,
Marvo,
Sean Kelly,
Marvo,
