Discuss Variable Speed Grinder in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
H
hmtiling
Hello all.
Need a new variable speed grinder for grinding polishing etc.
What do you guys recommend?
many thanks
Concrete guy
Gary probably has a 9565cvl which Makita no longer make, which is a shame as it was a very good machine and generally bomb proof.
It's been replaced with the SA5040 which is no where near as good.
If you want a polisher go for a Flex L1503 (1200-3700 rpm) <----dedicated polisher.
If you want a variable speed grinder then the Flex L1506 (2200rpm-6800rpm) <----a slower grinder than can do a bit of polishing
When buying a variable speed machine (whatever manufacturer) choose something that's going to be used closer to the higher end of it's speed range. You'll find it has a longer life span and won't overheat when used for extended period of time.
Concrete guy
Or do you go for a wet/dry polisher to cover all possibilities??
A dry variable is more versatile and suitable for tiling.
Wet machines are pretty dedicated to wet polishing only and tend to have smaller motors.
CJ
I went to a tool trade show last Friday. Flex had a stand. They forgot to pack polishing machines
Spoke to our Richard (365 Drills)
Reply to Variable Speed Grinder in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
Hi all. As title suggests. Used to use this forum a while back but seems my account was deleted...
Teejay
