Currently reading:
Bellota Cutters
Discuss Bellota Cutters in the Tiling Tools area at TilersForums.com.
Spare Tool
When a company can produce a cutter that will snap off a >20mm slither off a 600mm wide tile, every time, then that will be a great tile cutter - so far, it doesn't exist. At the moment, we have adequate cutters.
20mil???...how about 10 ;)
Bill
That is not what I wrote....I asked for a 20mm strip off 600mm wide tile........... you have cut a 10mm strip off a 30mm wide tile.............
I don't see the relevance of this infatuation of cutting thin strips off thin strips as they never get used unless your setting out is poor.........
Italy
hey tom.
you mean you need a tile cut into 58cm?
Spare Tool
The tile was 600 long, don't matter how wide 30mil or 600 fact is the result will be the same, what's setting out got to do with being able to cut 10 or 20mil off end of a tile, I've used many different kind of cutters and the sigma is the only one I've used that will take such a small slither of the end of porcelain so in my honest opinion they are a Great cutter, have you tried using one Tom?
Italy
long but I arrived.
I do not understand if you need 29 cm or 1 cm
latest picture, note that the thickness of the tile.
It is less than the width.
you can use as a toothpick.;)
IMG_0732.JPG IMG_0734.JPG IMG_0735.JPG IMG_0736.JPG IMG_0739.JPG IMG_0740.JPG
Bill
long but I arrived.
Very nice Antonio but that still isn't 20mm off a 600mm square. I am not bothered about cutting thin strips from 20mm pieces. I want a manual cutter that will do it EVERY time and not 1 in 2 attempts.
Italy
you never okay anything. (Like my wife) lol.
however, I make less effort.
you always carry water cutter. heavy and tiring.
now that tom installed water cutter.
antonio finished work. ahhaha
me, old. I have to make little effort and so many meters. :)
Reply to Bellota Cutters in the Tiling Tools area at TilersForums.com
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber floor in our barn conversion. The area is large, 21m x 8m. Having spoken to various UFH suppliers I...
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
