Discuss Bellota Cutters in the Tiling Tools area at TilersForums.com.
When a company can produce a cutter that will snap off a >20mm slither off a 600mm wide tile, every time, then that will be a great tile cutter - so far, it doesn't exist. At the moment, we have adequate cutters.Good cutters, seem stronger than Rubi.
But Sigma - aah, now there's a GREAT tile cutter!
20mil???...how about 10When a company can produce a cutter that will snap off a >20mm slither off a 600mm wide tile, every time, then that will be a great tile cutter - so far, it doesn't exist. At the moment, we have adequate cutters.
tom, he mean 2 mm ...20mil???...how about 10
That is not what I wrote....I asked for a 20mm strip off 600mm wide tile........... you have cut a 10mm strip off a 30mm wide tile.............20mil???...how about 10
hey tom.That is not what I wrote....I asked for a 20mm strip off 600mm wide tile........... you have cut a 10mm strip off a 30mm wide tile.............
I don't see the relevance of this infatuation of cutting thin strips off thin strips as they never get used unless your setting out is poor.........
The tile was 600 long, don't matter how wide 30mil or 600 fact is the result will be the same, what's setting out got to do with being able to cut 10 or 20mil off end of a tile, I've used many different kind of cutters and the sigma is the only one I've used that will take such a small slither of the end of porcelain so in my honest opinion they are a Great cutter, have you tried using one Tom?That is not what I wrote....I asked for a 20mm strip off 600mm wide tile........... you have cut a 10mm strip off a 30mm wide tile.............
Ok can't see what difference it will make though, floor on at end of this month with 600's, will post pics, take it your a Rubi fan?Right cut 20mm off a 600x600....go on ...make sure it works every time. And yes, I have used all types of cutters.
long but I arrived.When a company can produce a cutter that will snap off a >20mm slither off a 600mm wide tile, every time, then that will be a great tile cutter - so far, it doesn't exist. At the moment, we have adequate cutters.
Very nice Antonio but that still isn't 20mm off a 600mm square. I am not bothered about cutting thin strips from 20mm pieces. I want a manual cutter that will do it EVERY time and not 1 in 2 attempts.long but I arrived.
I do not understand if you need 29 cm or 1 cm
latest picture, note that the thickness of the tile.
It is less than the width.
you can use as a toothpick.
you never okay anything. (Like my wife) lol.Very nice Antonio but that still isn't 20mm off a 600mm square. I am not bothered about cutting thin strips from 20mm pieces. I want a manual cutter that will do it EVERY time and not 1 in 2 attempts.
Reply to Bellota Cutters in the Tiling Tools area at TilersForums.com
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
