Discuss Stress fracture concrete 2 joining rooms ditra? in the Canada Tile Advice area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
2020Tiling
Have a kitchen / dinning room floor job, concrete floor. Where archway meets in the middle of the room there is a crack along the whole length from side to side, it's a very faint crack so would I need to ditra over the whole concrete floor as the customer insists on not having a movement joint were the crack is also the crack isn't in a straight line. The floor is uneven and has to be self levelled anyway ,so would a fibre slc not stop the crack from transferring to the tile? Tiles are Granite :smilewinkgrin:
hello
I would recommend to Ditra the floor, better to be safe then sorry :), would be interesting to know if the floor is heated and how big is it, wouldn't risk it just to slc it and tile it
2020Tiling
Will be a bit price difference adding ditra plus labour. it's not heated and 17 mtrs. I recon I need around 4 bags of slc to make it flat.
Ajax123
Sounds le the concrete wanted a joint at that point. Ditra is appropriate if there is no vertical movement but if there is vertical movement you will need a joint in the tile face as well
Stef
This started out as a hairline crack,
This was after two years, it cracked the limestone much earlier than this.
The company were advised at the time to go with Ditra but wouldn't listen.
area tiling
How do these poured anhydrite and hemi hydrate screeds perform under stress, do small fractures also end up being major cracks ?
Stef
I'm not sure, that's a question for Ajax,
On the calcium screeds I have tiled I have noticed very small cracks but only time will tell if they develop into a problem.
P
Peter
Are you getting many of these screeds round your way? Few and far between in Belfast thankfully.
Reply to Stress fracture concrete 2 joining rooms ditra? in the Canada Tile Advice area at TilersForums.com
Lowpaul22
