Discuss Opinions: Lightweight Adhesive in the Canada Tile Advice area at TilersForums.com.
Jack White
Just got a few bags of the tilemaster standard set white adhesive in what's the opinions on the lightweight adhesives on the market at the moment?
Many thanks
Jack
Spud
the tile master light weight is an excellent product I use it a lot when fixing the thin tiles , mosaic and wall tilng with porcelain , high yield excellent grab , you need to mix it with more water to a loose consistency but it firms up in the bucket after a few minutes and is lovely to work with
Jack White
Thanks for the response how many square metres do you get from one bag roughly because if you do get 9/10 square metres out of a bag it really would be a brilliant product
P
Perry
Gary shush :lol:
283
Leyland
No secrets Gary........let em know! :hurray:
How many metres do you tend to get Gary/Pete from a 15kg unit using say a 10mm notch on a relatively decent substrate? How many metres would you get from a normal flexi adhesive?
P
Peter
Mark, did you ever get a Northern Ireland supplier sorted? Busting to try out some of the range but the only option at present involves bringing a pallet over myself.
1,098
Somerset
Personally I find that Tilemaster Adhesives Lightweight saves tiling time. The grip on walls is outstanding, press and twist and forget it - even with 600x300 tiles, It makes tiling the top of window recesses much quicker, and you can tile straight down from a bath edge to the floor with hardly any messing about. I discussed this with my tile supplier who tells me that it uses a new technology using glass particles - apparently no other adhesive manufacturer has this technology at the moment. Mark from Tilemaster might be able to advise if my information is correct. So quite apart from better coverage per bag, it measurably saves you time when fixing a whole bathroom.
Reply to Opinions: Lightweight Adhesive in the Canada Tile Advice area at TilersForums.com
