Currently reading:
Issue with Granfix Flexible Fastset
Discuss Issue with Granfix Flexible Fastset in the Canada Tile Advice area at TilersForums.com.
Old School
Hi,
This is my first post! Just a question to see if anyone has any experience using Granfix?
I have used Granfix Flexible Fastset for a job in which the tile shop supplied this adhesive. I have never used this adhesive before but the bag was labelled as fast set suitable for underfloor heating, wood, porcelain and waterproof.
The customer layer 18mm of marine ply and then laid Wediboard. He then fixed the underfloor heating and I came into screed the floor with the Granfix. I then tiled the floor the day after. When I tile I always apply my adhesive to the whole tile and then fix to floor.
However, one month later the customer explains to me the tiles are lifting off the floor. When I go to see what has happened I see the tiles have lifted and once the tile is removed it is clean, as if no adhesive has been applied. All the adhesive has large cracks in it.
The underfloor heating was put on 3 weeks after the job was complete. So I can't see this being the explanation.
Has anyone experienced this problem with this adhesive?
I have never seen this before and always use the same method that I have used in the past 26 years with my preferred adhesive, and think it is strange this happens on an adhesive I have never used before.
Old School
The job was complete in February and the customer messaged me in May to say the tiles felt loose and grout was coming away. I did notice the under floor heating was on 19 degrees!
I think you may be right in thinking they didn't turn it up gradually and stuck it on full wack.
I have never seen this before!
Perhaps the customer was trying to use the underfloor heating to heat the whole house!
thanks!
Hi Old School i use granfix adhesives all the time and never had problems ,thats not my way of fixing tiles (one at a time) but i cant see that being the problem,i would take a guess at the underfloor heating being put on to soon and not gradually,the problem you have now is are they going to tell you that they did everything as they should have,and to be honest ill bet they couldnt wait to put it on full blast when you had gone ,but im sure they wont tell you that,good luck and as i say i have used granfix for a long time now without problems i find it good to use
AliGage
Subscribed
My guess would be thermal shock. If you spread the adhesive direct to the back of your tile and there is none on the tiles now that have popped. To me that screams thermal shock.
As rookery said. Do the cracks follow the cable runs? Might be worth a call to the tech support of the UFH Manufacturers. Ask the question that if their technicians came out for an inspection would they be able to high light thermal shock from that inspection.
as for getting the rep out ,well if they are anything like bal you wont get far with the complaint ,athough i have only had two minor problems with bal, myself and the customers conserned got letters back that even a top scientist couldn,t even understand on an a 4 sheet of paper,but broken down all it said was that the product was up to bs and the wasnt prepared to help,that,s why i dont use bal anymore ,idiots
Old School
Thank you all for your replies!
I can't be sure about the preparation the customer did. It was ok but can't be sure unless looked at.
I have some images of the tiles and adhesive. Like I mentioned before I layed the tile by adding the adhesive first to floor and then to back of tile to create a full bond. The customer said the tiles felt loose and Photo 1 shows how the tile looked as I lifted it. Photo 2 is the back of the tile, you can see the adhesive hasn't bonded to the tile at all. You can also see the cracks in photo 3 and 4 but they don't follow the lines of the under floor heating.
Apparently a rep is due to check the job from Granfix but not sure when this will be. I see somewhere about a possible change in formula in the adhesive due to EU regulations but can't be sure on this. A sample was sent from this job for testing and test came back ok, but i think they were testing to see if I added anything to the mix to make this happen, but I did not do this.
What do you think?
Photo 2
Photo 3
Thanks,
Old School
Old School
I don't think the images appeared properly. Ashame as it shows how the tiles look as they were lifted.
Not sure how I can insert them so you can all see?
I have a rep coming to have a look tomorrow so I can update on any answers.
I spoke to the Under Floor Heating company which was WarmUp, and they have said that turning the temperature up so high would not have affected the tiles in that way, and would be down to adhesive failure.
Thanks,
Old School
Reply to Issue with Granfix Flexible Fastset in the Canada Tile Advice area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed most of our floor to accommodate tiling 800x800 porcelain over an uneven floor. The gap from defrac...
