dull mosaics after grouting
oleras
Howdy folks, first post.
I tiled my bathroom last week with ceramic wall and floor tiles. I put in a mosaic ceiling to floor drop behind where the sink will be and also as a bath surround. natural stone/marble mosaics.
the thing is i didnt seal them before grouting them:mad2: . Now they are as dull as dishwater !
I went back to the tile place and they sold me a ph neutral cleaner to scrub them with, they look great when they are still wet but dry to a dull again, i have tried buffing them and buffing them but no good.
what will i do next ? i want to get them sorted before i seal them or would sealing them give me back my shiny mosaics ?
broken link removed
Sealing will only seal in the dullness. It sounds to me like you need to clean the mosaic bit with a Cement Residue Cleaner. Lithofin do one, as do HG. Follow the instructions carefully as they are acid based. Hopefully this will clean your tiles up ready for sealing. Again, both companies mentioned do good products for sealing stone.
Grumpy
Thanks for the quick reply, i will get some of that cleaner today. Fingers crossed.
Added a pic link to the mosaics.
Aqua Mix do a range of products including a high gloss sealer and also Enrich And Seal. Their products are water based so no nasty fumes
Can we sort of get this right :
Travertine should be sealed after grouting if you seal it before you are closing the pores of the stone and reducing grout grab.
Fixing stone commands a premium because its a longer process than ceramics and takes understanding, sealing it first to make the job quicker contradicts the latter.
When you seal or intensify after grouting you can only seal in what you have left on the tiles. If the tiles are clean then you dont get a problem.
Using a grout such as Mapei ultracolour with a propper grout float to grout, leave untill tiles get cloudy (15/20 mins) and wipe any grout from tiles with a hydrophilic sponge rinsing it out after every pass. Leave tiles again untill cloudy and repeat. When tiles are dry dust off the surfave removing any stubourn grout with a stanley blade, when clean seal.
This is how it should be done and your not wasting money on cleaners :thumbsup:
tiler
Well yes on unfilled trav you wouldn't seal before grouting because the grout has to fill the holes. But I think I would seal all other stone before I grouted is this correct?
In the factory the slabs are cut from blocks have their surfaces filled either by hand with a trowel or machine with brushes either way the stone is wet. As the stone is filled if there are holes or large pores with air or water in them they do not get filled leaving empty holes or pores after the process is finished. When you grout a Trav floor you do 2 things you fill your grout lines and any holes or pores that are missed at the factory this is why you should always use a fine grout on travertine.
When the floor is dry you seal it to prevent staining of the tiles and grout or intensify it to enhance the colour.
tiler
oleras,
Branty,
oleras,
Branty,
