Shower enclosure problems
Was the tray fitted on top of the floor tiles and could it be the tray waste which is leaking through.
Did the plumber fir the tiles - his fixing method is incorrect - dot and dab.
The wall and floor tiles should be joint bonded assuming they are the same tiles.
you could try blocking the waste and showering the problem corner again, that would show whether the leak is from the tray or the waste
From the pictures you've posted, I would say it's definetly leaking from the bottom of the verticle post and needs stripped out and refitted again. To check the drain, you could just run the shower hose directly into the drain.....
Created on iPhone.....
yeah i guess that's easier but would work either way :smilewinkgrin:
Were the vertical bar meets the base channel looks like a pool of water running back to the corner
I've looked at the photo's a few times over and i have to ask the question. The tiles are cut down to the tray aren't they? Or were the walls done first and the tray pushed into the corner? The photo to, unless it's my eyes playing me up looks like it's the later.
could be
the tray was fitted first but the op has said the tiles were cut tight to the tray so no gap for silicon to get in
Sedated,
AliGage,
Sedated,
AliGage,
