Discuss new builds in the UK Tiling Forum area at TilersForums.com.
P
paul damian
i was asked by a lady 2 days ago could i come over and check her tiles, she thought that some of the tiles were loose, her tiling had been completed by a reputable tiling firm. on arriving at the destination the lady led me to her utility room..above the work tops there was 5 row of tiles high by 7ft long, 4 inch tiles uneven edge. on pressing on the tiles and tapping them with my hands i could tell the only thing holding them together was the tile trim. anyway i was able to take them off with my hands, but it wasnt an adhesion problem and no amount of primer would off made a difference. the skimcoat finish plaster,hardwall, had come away from the wall completely blown off the wall, i pointed out that this was the problem, the lady was distraught , not only was the utility room bad, the kitchen splashback was the same, the main bathroom, and the en-suite. whats going on is it a case that everything has to be rushed these days, did they not wait until the skimcoat dried out , has the the finish coat plaster been hit with frost, did they not bother to wet the sand and cement plaster before applying the hardwall. any answers.
Deleted member 9966
how old is the new build paul? she should really go back to the house builder and complain about the finish.
P
paul damian
about 18 months red, the lady is so upset, main builder doesnt want to know, pasted the buck on to the tiler, not his fault what i can see. just no adhesion between plaster and hardwall. its a mess, any ideas what caused it.
Deleted member 9966
it really is the house builders problem particularly as the house is still so new.
is it a well known or national house builder or a local?
doug boardley
my guess is it's been tiled day after being skimmed, weight of ties have de-bonded skim from basecoat:thumbsdown:
A
aqua blue
Paul, was the wall primed and have you seen blows anywhere else apart from the tiled areas?
Reply to new builds in the UK Tiling Forum area at TilersForums.com
