advice fixing natural stone tiles
Don't worry, you don't have to seal them before you fix them, only before and after grouting. This can be the case depending on the stone, a polished limestone such as Jura would not require sealing where a white limestone such as Flax would. Always check
And about fast set adhesive - never use fast set adhesive, if you don't know, how the stone reacts on fast set adhesive. This is a pretty brave statement considering fast and normal set adhesives perform the same if recomended for use on stone except for the obvious speed of set
Fast set addy actually shouldn't be used for stone at all. It can be only used for non absorbant stone - granit etc. You are confusing rapid with flexi in certain cases.
With rapid set addy you risk that stone will bend or it'll crack.
And you definitely can't use fast set addy for heated areas or for thick bed adhesive. These 2 sentences are indeed not your best I think
Play nice guys..................:thumbsup:
IF you think that the manufacturers instructions and fixing techniques are not perfect then that is your problem - don't make it someone elses!
With porous stone a damp sponge (whether clean or otherwise) will affect the acceptance of a sealant at a later stage in the process. This type of stone should be sealed before fixing.
Timeless John.
This is a pretty brave statement considering fast and normal set adhesives perform the same if recomended for use on stone except for the obvious speed of set - not true, speeding procces means a lot for different stones and spacially means a lot if stone is very thin - up to 15 mm, and when you use more then 10 mm of addy in some areas - which is with large format stone quite common
no, I'm not and I never use non flexible adhesive for stone. Do you?
I've explained those two above.
To be honest, for floor I try to use only rapid set flexible as non rapid set has a tendency to sink over the night, leaving the floor with 1 mm lips.
But it take me lot of time to prepare the floor, so I can use rapid set and it took me more then 3-4 years to find out, how far and with wich stone I can go with rapid set adhesive.
And I still don't know everything about the stone and I'm still learning new things every day.
But for newbies, to be on the safe side is best not to use rapid set addy for stone at all.
If you'll be on the Court 3 times with your client and manufacturer(as expert and adviser), then you'll find out quite soon, that manufacturers are not always correct and there are hundreds new factors involved with every job and every kind of stone.
That i agree with...:thumbsup: but certain ones do need careful thought though.
The short answer is no one should be fixing large format natural stone unless they are experienced
tel
thanks everybody for the handy tips.well i started the job last week and all is well.the stone tiles were silk stone a type of limestone i believe.they are very soft to cut with the disc cutter and easy to work with. all the tiles have a bullnose edge to them and after every cut i must bullnose the the tile to fit but i have variose sanding discs.i decided due to the bad weather to seal them when i am ready to grout after testing a tile before i started.i have just got to have a sponge ready.not so bad im paid by the day so no need to rush and make mistakes. its looking very impresive for my first stone job especially with the set in lights ect its a plush and expensive bathroom,good for the port folio.i will send in some pictures when finished.once again thanks all.:8::thumbsup:
boxhead,
beanz,
boxhead,
beanz,
