White Room
Out the door might be more appropriate:yikes:
Discuss Is my tiler using the correct adhesive ? in the UK Tiling Forum area at TilersForums.com.
PVA will become "live" again in contact with moisture. Dispersion adhesive contains alot of moisture so the pva will not do vey much apart from become slippy. There is a very good thread on here about primer v pva which I am sure Dave has a link for and will post it up for you.Call me old fashioned, but I'd prefer not to just accuse him of doing it wrongly, but simply ask why he is using certain adhesives, preparations etc, when "isn't X,Y,Z what is more usual"
I think I am right in thinking that cement based adhesive is the best choice because it goes off by chemical reaction, not evaporation, the latter being impeded by large format, non porous tiles where moisture will take an age to disappear, but what is the story about PVA ?
...as is Ardex D30, but not large format and you must have a porous substrate.Just to point out there are a couple of tubbed ready mixed adhesives that are suitable for porcelain tiles, though large format porcelain do not fall into that bracket
Granfix Multifix is one of them ...
http://www.tileadhesive.co.uk/PDF files/Multifix Adhesive.pdf
No Leatherface I didn't. Send it again?Grumpy
did you get my PM ?
The very chap Hugo.
Reply to Is my tiler using the correct adhesive ? in the UK Tiling Forum area at TilersForums.com
